Date/Time: Wed, 05 Mar 2025 04:10:30 +0000
Settings Menu - Black
View Count: 681
[2022-01-15 17:47:16] |
User671263 - Posts: 2 |
When I go into general setting or trade service settings I get a black screen and no options like I would normally have. It almost looks like a programming screen. How can I correct this ?
[2022-01-15 17:53:49] |
Go to Global Settings >> Graphics Settings and check the color settings that begin with: Settings Windows: Make sure the foreground and background colors make sense to have a proper visible view. They must not be the same. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-01-15 17:54:18
[2022-01-15 18:03:05] |
Refer to: Settings Windows Interface: Colors and Font Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
