Date/Time: Mon, 02 Nov 2026 23:58:35 +0000
[User Discussion] - How to configure Alerts
View Count: 1067
[2022-01-15 16:22:48]
User359761 - Posts: 1
I would like to configure an alert when BID Volume >=10 and ASK Volume = 0 on ES Rev 4T ( see attachment).
Could you please tell me how to draw a line if the condtion is reached.
Thank you in advance.
imageSound Alerts.png / V - Attached On 2022-01-15 16:19:23 UTC - Size: 161.1 KB - 354 views
[2022-01-17 15:40:23]
John - SC Support - Posts: 48388
Generally, this is easier using ACSIL, as the access to the separate Bid and Ask data is more readily available.
But, it can be done in an alert, you would have to use the BVAP and AVAP functions in your alert and you would need to put in a lot of options to cover the different price levels. Refer to the information here:
Study/Chart Alerts And Scanning: BVAP
[2022-01-17 21:24:52]
Sawtooth - Posts: 4359
If you want an alert of the values at only the Low of the bar, try this formula on the Alerts tab of a Color Bar Based On Alert Condition study:
=AND(BVAP(L,0)>=10,AVAP(L,0)=0)
Follow these instructions to mark the bar where the alert occurs:
Color Bar Based on Alert Condition: Coloring Subgraphs of Other Studies
