Date/Time: Wed, 05 Mar 2025 04:23:39 +0000
canot move charts verticay
View Count: 566
[2022-01-15 15:43:23]
User427561 - Posts: 217
Iam using my old computer to avoid the frequent crashes I was having with my new comuter which seems to be worind as far as crashes.
hower when i grab achart in a chartbook with the hand i am only abel to move the chart horizontay but not verticaly in al regions and tme in instances.
any sugestions to aolow veertica movements?
[2022-01-15 18:07:21]
AC7303484 - Posts: 28
Global Settings --> Then Tool Settings --> "Support vertical scaling/movement with hand tool" -- Make sure that is turned to "yes", the default setting on install is no.
[2022-01-15 19:11:20]
thanks
Date Time Of Last Edit: 2022-01-15 19:12:00
[2022-01-17 04:07:24]
This is explained in this section here:
Chart Drawing Tools: Vertical Movement and Scaling (Hand tool)
Date Time Of Last Edit: 2022-01-17 04:07:45
