Date/Time: Wed, 05 Mar 2025 04:26:10 +0000
Failed login after update - v2345
View Count: 566
[2022-01-15 14:23:51]
SpearChucker - Posts: 104
**Update**
This now appears to be a Rithmic issue. Last time it wasn't. Please disregard this support request. Thanks.
This has happened for several updates. In multiple instances in have installed (not the original installation), after update I'm no longer able to login to Rithmic Direct -DTC. Here's the Message Log entry and a screen capture of the error.
I can copy my original installation to all instances and change the connection settings and get everything to work again, but I shouldn't have to do that.
The Rithmic accounts are currently active and no login credentials were changed. I was successfully logged in just before updating SC. Any ideas?
Msg Log:
Rithmic Direct - DTC | Using server connection: Rithmic Paper Trading-Chicago Area-Non-Aggregated | 2022-01-15 09:08:54.806
Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50500 | 2022-01-15 09:08:54.806
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-01-15 09:08:54.806
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-01-15 09:08:54.806
DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-01-15 09:08:54.806
Rithmic Direct - DTC | Network connection to server complete. | 2022-01-15 09:08:54.874
Rithmic Direct - DTC | Starting socket receive thread. | 2022-01-15 09:08:54.874
Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-01-15 09:08:54.874
Rithmic Direct - DTC | Sending logon request message. | 2022-01-15 09:08:54.874
Rithmic Direct - DTC | Received logon response. | 2022-01-15 09:08:55.052
Rithmic Direct - DTC | Server Name: . | 2022-01-15 09:08:55.052
Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-01-15 09:08:55.053
Rithmic Direct - DTC | Logon error received from server: permission denied | 2022-01-15 09:08:55.053
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-01-15 09:08:55.053
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-01-15 09:08:55.053
Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-01-15 09:08:55.069
DTC Client socket (1) | CloseSocket call. | 2022-01-15 09:08:55.069
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-01-15 09:08:55.069
Rithmic Direct - DTC | Disconnected. | 2022-01-15 09:08:55.070
Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-01-15 09:08:55.070
DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-01-15 09:08:55.131
DTC Client socket (1) | Closed. | 2022-01-15 09:08:55.131
File >> Disconnect selected. | 2022-01-15 09:08:57.886
DTC Client socket (0) | CloseSocket call. | 2022-01-15 09:08:57.886
Rithmic Direct - DTC | Disconnected. | 2022-01-15 09:08:57.886
Date Time Of Last Edit: 2022-01-15 16:33:08
imageLogin.jpg / V - Attached On 2022-01-15 14:23:05 UTC - Size: 26.05 KB - 142 views
[2022-01-15 17:25:09]
This is the relevant message:
Refer to:
Rithmic Trading Platform Service: Permission Denied Resolution Procedure
