Date/Time: Sun, 04 Oct 2026 04:18:35 +0000
How to conduct real-time buy and sell operations?
View Count: 879
[2022-01-15 10:59:28]
User636887 - Posts: 2
Hello, I already have a real account in AMP and have opened it (COMEX/Globex (Level 2) Depth of Market/(Level 1) Top of Book), there will be a monthly payout of $13.
And it is also possible to conduct real-time simulated trading directly through SIERRA CHART, but when I want to switch to a real account and trade, the display fails. How can I operate and modify it so that I can directly conduct real-time trading in SIERRA CHART?
And if I trade in real time through SIERRA CHART, what kind of fees will be incurred?
Or is there a better solution for SIERRA CHART?
I am new to futures trading, and I need to ask questions about a lot of things I don’t understand, please understand
Thank you looking forward to your reply.
[2022-01-17 15:10:15]
John - SC Support - Posts: 48095
Our servers show that you have your system setup to connect to CQG. If you have set this up properly, then all you need to do is to take your Sierra Chart out of simulation mode in order to trade live to your CQG account. Refer to the following for more information:
Overview of Trading: Difference between Simulated and Non-Simulated Trading Modes
When trading through Sierra Chart there are not fees from us (Sierra Chart). All your fees will be from your broker. You need to ask them about the fees you will incur per trade.
[2022-01-18 01:08:57]
Thank you very much.
I would like to add a question. Hope it can also be resolved.
I've set up the DOM transaction window to my liking. But if I want to open other charts for trading, how can I call out the DOM trading window that I have set up?
[2022-01-18 15:07:02]
Trading DOMs are Chart Instances. Therefore, just like you would do with a chart, you need to duplicate the Trading DOM and then change the symbol. Refer to the following:
Using Chart Templates: Duplicating Charts / Template Charts
