Date/Time: Wed, 05 Mar 2025 18:28:14 +0000
Trouble down loading Sierra Chart
View Count: 570
[2022-01-14 19:40:19] |
rickit - Posts: 8 |
I recently acquired a new laptop and am having trouble downloading Sierra Chart software onto my computer. The error message reads code #3, can not find specified path. I am running Parallels on a Mac which I have done many times in the past. Thank you in advance, Rick Reynolds |
[2022-01-14 20:40:47] |
Tony - Posts: 552 |
You could download Sierra installer from Mac web browser, and Parallels has access the Mac Download folder.
Date Time Of Last Edit: 2022-01-14 20:43:05
[2022-01-15 05:06:05] |
Try using the ZIP installer: Software Download: Sierra Chart Zip Installer Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
