Date/Time: Fri, 02 Oct 2026 11:30:06 +0000
Storing Sierra Data in cloud location
View Count: 1738
| [2022-01-14 18:40:30] |
| User963221 - Posts: 20 |
I have multiple computers that I can end up trading from and it would be nice if I could keep my settings in a cloud based location. Will there be any problems storing C:\SierraChart\ folder in a cloud or shared location location? Thanks Kurt |
| [2022-01-14 20:39:56] |
| John - SC Support - Posts: 48086 |
There are all kinds of issues that can arise from doing this kind of setup, where you are accessing the data directly from the "cloud" directory. Sync'ing software is a better alternative, as you still have local copies of the files that can be sync'd to a cloud setup. Or you can copy the files between the installations. Refer to the following: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
