Date/Time: Wed, 05 Mar 2025 18:04:56 +0000
the chart is not connecting
View Count: 435
[2022-01-14 15:12:54] |
User229460 - Posts: 24 |
this is the third time over the last 5 days that the yellow tab is up but it fails to change to green
[2022-01-14 15:59:15] |
We see you are using Transact. We cannot help with Transact connection problems. For information about the new connectivity method available, refer to: *Important* Priority Message to Transact Users Please move off of Transact as soon as possible, for your own good. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-01-14 16:10:06
