Date/Time: Tue, 08 Sep 2026 21:31:34 +0000
Graphics Settings Configuration
View Count: 780
| [2022-01-14 03:11:09] |
| RHudson85 - Posts: 33 |
Can someone tell me where the graphics settings are stored at? I have Sierra on multiple computers. I figured out how to get the chartbooks transferred between the 2. I was hopeful that the graphics settings would transfer as well and they did not. I have it all set up on one.....I would prefer not to have to redo my graphics settings on each one. Thank you |
| [2022-01-14 15:36:38] |
| John - SC Support - Posts: 47806 |
The file is named Sierra4.config and is in the main Sierra Chart installation folder. Refer to step #5 of the following documentation which gives information on the various files in Sierra Chart: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
