Date/Time: Sat, 26 Sep 2026 16:33:16 +0000
Numbers Bars - Toggle Text Display
View Count: 872
| [2022-01-14 00:59:43] |
| SavantTrader - Posts: 112 |
Dear SC Support: For the Numbers Bars Study, is there any way to toggle the text display? For example, while scalping I'd like to quickly be able to toggle between these two settings: [Column 1 Numbers Bars Text (In:16)] : (No Text) | (Bid Vol x Ask Vol) Is there a way to at least set a keyboard shortcut or a customized button to do this? As always, thank you. |
| [2022-01-14 03:44:54] |
Yes indirectly you can do this by creating different configurations of the Numbers Bars study that are saved as Study Collections and changing between Study Collections on the chart using keyboard shortcuts: Control Bar: Control Bar Study Collection Buttons and Keyboard Shortcuts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
