Date/Time: Wed, 05 Mar 2025 04:28:52 +0000
Weekly Volume POC Incorrect
View Count: 619
[2022-01-13 22:45:14] |
AMGAMG - Posts: 10 |
Hi, my Weekly VPOC line should be around the 1106 or 1109 level I believe , however it's currently showing incorrectly at 1026.96. Can you please help me figure out which settings are incorrect? Here is a screenshot: https://www.sierrachart.com/image.php?Image=1642113728399.png Thank you! |
[2022-01-14 14:46:31] |
John - SC Support - Posts: 38380 |
How are you getting that Weekly POC? What study are you using and what are the parameters to define the week?
[2022-01-15 00:18:34] |
Hi, I ended up just deleting and reinstalling Sierra Chart and now it's showing the proper value.
[2022-01-17 16:23:17] |
You did not need to delete and reinstall Sierra Chart. At most you would have needed to re-download the data in the chart: Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart. And check the relevant Chart Settings, and Study Settings to make sure they are set as required. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-01-17 16:23:28
