Date/Time: Sat, 04 Jul 2026 06:17:14 +0000
MACD study - why 2 different MACD difference on parameters
View Count: 1304
| [2014-04-08 17:34:10] |
| User33681 - Posts: 37 |
First time I added MACD to chart the difference had two boxes. The next time I added MACD to another chart there was only 1 box for the difference. See sshots attached |
| [2014-04-09 04:38:20] |
There will be both Primary and Secondary color buttons for a study Subgraph when Auto Coloring is enabled. You will see the setting for that below the color button.
