Date/Time: Sun, 08 Nov 2026 20:58:13 +0000
Exchange Traded Spreads
View Count: 915
[2022-01-13 17:53:31]
User841161 - Posts: 357
I was able to chart a exchange traded spread(08Soyoil-10Soyoil) but was wanting the (10Soyoil-08Soyoil). I do not see that spread listed. Is there an easy way to reverse symbol to get correct chart.
All one needs to do is minus the (08Soyoil-10Soyoil)
imageSOYOIL01-13.png / V - Attached On 2022-01-13 17:53:23 UTC - Size: 87.99 KB - 316 views
[2022-01-13 19:34:09]
John - SC Support - Posts: 48459
What you are wanting is the same as multiplying by -1. Therefore, use this study:
Multiply Bars By -1
[2022-01-13 22:42:59]
Yes that works, is there a way to trade that spread through Sierra Charts. When I bring the Chart Trade Dom up it brings up the original spread (08 Soyoil-10AugSoyoil). Want to trade the (10Soyoil-08Soyoi
[2022-01-14 14:44:20]
If there is not an already existing exchange traded spread for what you want, then you could use the Spread Order Entry study. Refer to the information here:
Spread Order Entry Study
