Date/Time: Sun, 20 Sep 2026 01:15:41 +0000
Drawing a Line without a reset
View Count: 745
[2022-01-13 16:48:26]
User736544 - Posts: 2
How can I draw several lines without a reset. If I draw one line and click left to get out of it, I then have to go to menu and click on "line" and repeat this process. Is there any way one can draw one line, click to finish that line, then draw another line and only when done with all lines, right click or something to get out of Line Menu.
[2022-01-13 17:11:17]
John - SC Support - Posts: 47939
It sounds like you have the setting for Global Settings >> Tool Settings >> After Single Tool Use Change To set to something other than None. Set this to None and you should be able to do exactly what you are wanting. Refer to the information for this setting at the following link:
Chart Drawing Tools: After Single Tool Use Change To (Global Settings >> Tool Settings >> General >> Tool Options)
Also, be aware of the following setting as well:
Chart Drawing Tools: Right Click Exits Current Drawing Tool To (Global Settings >> Tool Settings >> General >> Tool Options)
