Date/Time: Tue, 06 Oct 2026 12:12:42 +0000
Floating Chart Values Window
View Count: 950
[2022-01-13 15:53:04]
RHudson85 - Posts: 33
Does Sierra have a floating chart values window that shows the OHLC and any other data associated with the candle in question (IE studies data, time of candle, etc). I like the crosshair but on some platforms you can click the mouse on a candle and get a pop up data window with all the information.
Thank you.
[2022-01-13 16:10:14]
John - SC Support - Posts: 48114
Yes, there are two different options - the Tool Values Window and the Compact Tool Values Window. Refer to the information starting at the following link:
Chart Drawing Tools: Viewing Tool and Chart Data When Using Tools
