Date/Time: Wed, 05 Mar 2025 02:35:00 +0000
Problem with Global Profit/Loss Management
View Count: 533
[2022-01-13 15:05:51]
User111577 - Posts: 5
I have a problem with the profit / loss management functionality and it is that even though I am trading with Micro ES, the loss/profit appears as if I am trading with E-Mini (that is, multiplied by 10 the value of the P&L), is there any solution or setting for that?
https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=59381
https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=59382
[2022-01-13 16:00:59]
John - SC Support - Posts: 38380
You need to ensure that your Currency Value per Tick is set appropriately for the instrument you are trading. Refer to the following:
Chart Settings: Currency Value Per Tick (Chart >> Chart Settings >> Symbol >> Symbol Settings menu)
