Date/Time: Wed, 09 Sep 2026 16:13:45 +0000
Equities market depth with TotalView
View Count: 732
| [2022-01-13 08:08:57] |
| MatZer0 - Posts: 36 |
Hi I have subscribed to IBKR US equity market depth "TotalView with OpenView". It is supposed to provide an aggregated coverage of market depth from multiple exchanges in a single feed How do I confugure SC to see that aggregated multi-exchange depth, not only depth from one selected exchange (I only found that option in your docs)? |
| [2022-01-13 15:17:14] |
| John - SC Support - Posts: 47815 |
We are displaying whatever Market Depth is being supplied by Interactive Brokers for the particular symbol. If they are sending an aggregated depth, then that is what we will be displaying. Therefore, you would need to find out from IB how they are doing this and whether you need to have a particular symbol. If it requires some special work on our end (they are sending the data separately from each exchange and then expecting us to consolidate it), then this is not supported. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
