Date/Time: Thu, 17 Sep 2026 18:32:14 +0000
Cannot backtest: Did not find FIELD_CODE_BEGIN_RECORD when expected
View Count: 859
| [2022-01-13 05:25:16] |
| User612901 - Posts: 25 |
hi, - when trying to run backtests i get error messages as below Trade Activity file unexpected condition. Did not find FIELD_CODE_BEGIN_RECORD when expected. Field code read: -1. C:\SierraChart\TradeActivityLogs\TradeActivityLog_2022-01-13_UTC.Sim22.simulated.data | 2022-01-13 00:09:38.087 * Trade Activity file unexpected condition. Did not find FIELD_CODE_BEGIN_RECORD when expected. Field code read: 0. C:\SierraChart\TradeActivityLogs\TradeActivityLog_2022-01-11_UTC.Sim22.simulated.data | 2022-01-13 00:09:38.094 * TradeActivity files query time: 0.510082 seconds. Entries: 0. Current queries: 1 | 2022-01-13 00:09:38.597 Trade Activity file unexpected condition. Did not find FIELD_CODE_BEGIN_RECORD when expected. Field code read: 0. C:\SierraChart\TradeActivityLogs\TradeActivityLog_2022-01-11_UTC.Sim22.simulated.data | 2022-01-13 00:10:31.775 * Trade Activity file unexpected condition. Did not find FIELD_CODE_BEGIN_RECORD when expected. Field code read: -1. C:\SierraChart\TradeActivityLogs\TradeActivityLog_2022-01-13_UTC.Sim22.simulated.data | 2022-01-13 00:10:31.775 * TradeActivity files query time: 0.001179 seconds. Entries: 0. Current queries: 1 | 2022-01-13 00:10:31.775 - i have downloaded current version.... same problem - am using SC data -assistancce appreciated |
| [2022-01-13 06:28:02] |
We think we know what the cause of this issue is. We are putting out a new version in about 20 minutes.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-01-13 06:28:12
| [2022-01-13 07:40:34] |
Thanks... Downloaded v2344..... started to backtest ok, then get similar error messages, and the notification (not responding) with an hourglass where my cursor would be Have tried twice so far... problem not fixed yet.... |
| [2022-01-13 07:40:35] |
| [2022-01-13 14:27:22] |
What exact message are you getting? The issue with opening a file that was probably leading to this condition definitely has been resolved: Trade Activity file unexpected condition. Did not find FIELD_CODE_BEGIN_RECORD when expected. Field code read: -1. C:\SierraChart\TradeActivityLogs\TradeActivityLog_2022-01-13_UTC.Sim22.simulated.data | 2022-01-13 00:09:38.087 * If you run into an issue where Sierra Chart is freezing it means you are back testing too fast. And also back testing can cause the user interface to freeze if it is happening at a high speed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-01-15 23:23:58] |
| User475862 - Posts: 37 |
I am having the same issue and getting the same error. it was working fine yesterday, and this am but now the simulation is not filling the orders. i am on Version 2343. Thanks
| [2022-01-16 00:48:24] |
The only thing we can think of to remove those errors, is to delete the files that are giving that particular error, then redo the back test. The complete path and file name for them is given. So you can easily delete them. We recommend exiting from Sierra Chart first before deleting them. Version 2343 is affected by the issue, but you are running 2344. The problem is resolved in that version. However, if the files are still giving that error you need to delete them. The error is harmless though. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-01-16 00:49:34
| [2022-01-16 14:04:48] |
after deleting the files and restating SC it is working again, Thanks
