Date/Time: Wed, 05 Mar 2025 02:05:48 +0000
Global Linking
View Count: 621
[2022-01-13 04:01:13] |
RHudson85 - Posts: 33 |
Is it possible to create a "global link" between items? I have figured out how to link multiple chart books in the same instance. But I am trying to create instances for other monitors and link these to the items on the main instance. Thank you. |
[2022-01-13 04:08:28] |
No there is no linking like this between actual separate instances of Sierra Chart.
[2022-01-13 04:16:49] |
It is possible to detach the chartbook and move it to another monitor? I have 8 different charts (all different timeframes to show the whole picture without switching through 8 different timeframes). There has to be a way around this? Surely I don't have to duplicate 8 charts every morning and arrange them on another monitor so they are linked to the main. Thank you. |
[2022-01-13 15:05:42] |
John - SC Support - Posts: 38380 |
You can not detach a Chartbook, but you can detach the charts. It sounds like this will work for what you need. Just detach the charts and set them as you want them on your monitors. Refer to the following for more information: Detaching and Attaching Chart Windows For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
