Date/Time: Sat, 19 Sep 2026 16:03:53 +0000
Chart Scaling Includes All Studies
View Count: 723
| [2022-01-12 23:07:23] |
| RHudson85 - Posts: 33 |
This is my first day using Sierra and I am experiencing a number of things I am trying to correct. This is the first I am posting......The chart scaling is set up to include all studies, this means that it is including all the SMAs on the chart and scrunching up the candlesticks to do so. I know on Tradestation there was a box you could uncheck to "include studies in chart" that would allow the candles to stretch out a bit and give a better picture. I have attached a screenshot that shows all the candles bunched up at the top of the window so that it can include the blue SMA at the bottom. Please help. Thank you https://www.sierrachart.com/image.php?Image=164202876276.png |
| [2022-01-12 23:55:53] |
| John - SC Support - Posts: 47939 |
Refer to the following: Chart Scale and Scale Adjusting: Basing Scale Only on Price Bars For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
