Date/Time: Tue, 26 Nov 2024 04:20:33 +0000
Rectangle Config
View Count: 1411
[2014-04-08 15:01:14] |
User76055 - Posts: 18 |
Is there any way to duplicate the Rectangle Config drawing box to other charts, say if you draw on a 5min chart on ES then it also duplicates it on another chart which is 1 min chart. Thanks
[2014-04-08 19:05:36] |
Yes. Refer to: https://www.sierrachart.com/index.php?l=doc/helpdetails72.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
