Date/Time: Wed, 05 Mar 2025 02:34:19 +0000
Standard Deviation Channel
View Count: 1177
[2022-01-12 18:53:29] |
User427421 - Posts: 40 |
Hello, I've been looking for this study but couldn't find it. Is this available in SC? Screenshot attached.
![]() Attachment Deleted. |
[2022-01-12 23:28:19] |
John - SC Support - Posts: 38380 |
Take a look at this study: Standard Deviation Bands For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-01-13 02:12:39] |
Thanks, I tried it but it's not quite the same... The one I'm looking for gives me a straight channel like in the new screenshot attached. The closest I could find was the Linear regression end channel but it's not exactly the same.
[2022-01-13 04:05:49] |
Yes do have a look at this study: Linear Regression End Channel And also this Drawing Tool: Chart Drawing Tools: Linear Regression Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-01-13 04:05:56
