Date/Time: Wed, 05 Mar 2025 01:25:14 +0000
Settings Suggestion
View Count: 439
[2022-01-12 18:31:19]
User445772 - Posts: 3
Good day,
I wanted to ask if this could be implemented.
In the Settings window is it possible to add a feature that if you click the header "InputName", this will sort the Item Names in Alphbetical order from A through Z, and click again will sort from Z to A?
See attached screenshot.
Thank you.
imageSettings Option 1.png / V - Attached On 2022-01-12 18:30:11 UTC - Size: 67.45 KB - 136 views
[2022-01-12 18:41:20]
It is not something we are able to reasonably do. And it would mix up the list in such a way that would create confusion.
