Date/Time: Wed, 05 Mar 2025 18:06:12 +0000
can't see Label for Extend Bar Gap
View Count: 548
[2022-01-12 16:33:44] |
User846936 - Posts: 3 |
Hello, I can't get the Short Name Label for the "Extend Bar Gap Until Future Intersection" study to appear on the chart. Please see screen shot. Any ideas? Thanks.
[2022-01-12 17:10:12] |
We have to check but the type of line that this study uses does not support labels using those particular settings.
[2022-01-12 18:27:13] |
OK, not the end of the world. If there is a way to make a label, please let me know. I assume that this study can only use a line, despite all the different choices in the dropdown? (I was trying to get a line to show at the other end of the gap, to show the full range of the gap, but again, not the end of the world.) Thanks |
[2022-01-18 05:12:06] |
Yes that is true. Just a line.
