Date/Time: Thu, 06 Mar 2025 16:11:51 +0000
Question about Denali
View Count: 636
[2022-01-12 09:07:34]
Trader & Sierra++ developer - Posts: 110
Hi Sierra,
Before i subscribed to real time Denali CME data, i was able to load CME and EUREX delayed data.
Since i subscribed to real time Denali data for CME only, i cannot access delayed EUREX data anymore.
Is it normal (hope not) or is there anything i made wrong ?
Thank you
[2022-01-12 14:41:03]
Install a separate installation of Sierra Chart:
Using Multiple Data and Trading Services at the Same Time
In that installation, you can access this delayed data, by following these instructions:
Set "Global Settings >> Data/Trade Service Settings >> Current Selected Service" to "SC Data-All Services".
Press "Ok"
And then translate the symbols in your Chartbooks and Sierra Chart using this command:
Edit Menu: Edit >> Translate Symbols To Current Service
Date Time Of Last Edit: 2022-01-12 14:41:49
[2022-02-07 08:24:49]
Hi Sierra,
I did follow your advice, it works, but Euronext FCE is not refreshed automatically and nothing happens in the DOM. I have to reload the chartbook to get new data... What should I do ?
[2022-02-07 18:55:19]
John - SC Support - Posts: 38439
You are not setup to get the real-time data from EURONEXT and that data is not streaming delayed. Therefore, the data will update according to the setting you have for Global Settings >> Data/Trade Service Settings >> Intraday Download Interval for Non-Real-Time Symbols. Refer to the information here:
Sierra Chart Historical Data Service: Introduction
