Date/Time: Wed, 05 Mar 2025 18:31:45 +0000
Sierra TT/Fix or CQG/fix for non TETON markets
View Count: 687
[2022-01-12 03:55:51] |
User155017 - Posts: 41 |
Hi, I think TETON is a great option for CME, and soon EUREX. 1)What about other exchanges such as ICE or south america/asia, which are available on TT. Will it be possible to trade them using Sierra TT? 2)Alternatively, does the CQG fix connection work for those exchanges? 3)Are iceberg orders supported by either TT or CQG via Sierra on those non TETON exchanges? Thanks JJ |
[2022-01-12 15:11:01] |
1. You need to use CQG for these exchanges: CQG Trading Platform Service 2. Sierra Chart does not support CQG FIX. 3. No. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-01-12 18:27:09] |
1)As an existing Sierra TT order routing customer( which for me worked well), can I keep using it with non Teton markets, and switch to TETON only for those markets? 2)Sierra TT was (also before Teton) only for CME and Eurex? 3)What other options to use TT are available on SC? Date Time Of Last Edit: 2022-01-12 18:29:18
[2022-01-14 05:36:55] |
1. Yes. 2. Yes. 3. No other options. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
