Date/Time: Tue, 26 Nov 2024 04:20:30 +0000
laptop renewal
View Count: 1098
[2014-04-08 14:41:11] |
julian pineda - Posts: 60 |
Hi, I´m going to change my PC, could you send me to my e-mail all the information I need?: Username Password download SC setup link etc thanks¡ |
[2014-04-08 16:16:46] |
Sierra Chart - Max - Posts: 5731 |
1. To copy your Sierra Chart setup to a different computer, refer to help topic 15 here: https://www.sierrachart.com/index.php?l=doc/helpdetails15.html 2. For a new installation you can download Sierra Chart using this link here: https://www.sierrachart.com/downloads/SierraChartSetup.exe And you would need to follow the OEC setup instructions here: https://www.sierrachart.com/index.php?l=doc/openecry.php#SetupInstructions In both cases you will want to login to Sierra Chart using the same login details (username and password) that you used to login to the Support Board. Let us know if you would like to reset your password and have it sent to your email on file. Sierra Chart Support Date Time Of Last Edit: 2014-04-08 16:20:19
[2014-04-08 16:25:26] |
I loggin to the SC support board directly from SC platform. i dont remember my password and username
[2014-04-08 16:40:26] |
Your password has been sent to the e-mail address for your account.
Sierra Chart Support |
