Date/Time: Wed, 05 Mar 2025 01:43:26 +0000
Does interactive brokers work fine with Denali feed?
View Count: 764
[2022-01-12 02:54:05]
User562383 - Posts: 10
I want to trade /ES and /NQ futures with DOM. I currently have a TDAmeritrade and Interactive Brokers account. My understanding is you do not support TDAmeritrade and I have read several complaints about Interactive Brokers. Will IB work fine as long as I use the Denali feed or will I still run into execution errors or delays in the data feed? Should I get a new broker or is IB fine? I think I want Service Package 11, correct?
[2022-01-12 20:52:17]
John - SC Support - Posts: 38380
Our primary recommendation is to use our Teton Order Routing service, which would require a different broker. You would then be using our Denali Exchange Data Feed as well. Refer to the information here:
But, if you want to use Interactive Brokers, then you can do so with Sierra Chart and you can use the Denali Exchange Data Feed with it. You will not run into issues with the data feed, but you may have other issues. Refer to our information on Interactive Brokers here:
Interactive Brokers Trading Service: Introduction
If you do stay with IB, then you will need to go through the Setup Instructions for them on the page above.
And for the Denali Exchange Data Feed, you will follow these instructions (which will give you information on the package you need):
[2022-01-12 22:21:41]
Thank you. From the Teton Order Routing service documentation:
To be able to use this service, you need to have a live trading account with one of the following clearing firms or one of their Introducing Brokers:
Advantage Futures (Clearing firm)
Dorman Trading (Clearing firm)
Stage 5 Trading (broker)
Phillip Capital (Clearing firm)
Edge Clear (broker)
ED&F Man (Clearing firm. Expected upcoming support.)
Ironbeam (Clearing firm. Expected upcoming support.)
Trade Pro Futures (broker)
AGN Futures (broker)
AMP Futures (Clearing firm. Expected upcoming support.)
NirvanaTS (associated clearing firm ED&F Man)
I have heard positive reviews from AMP futures. Teton order routing is not currently supported with them, correct? Do you know when it will be?
[2022-01-12 23:41:09]
Correct - AMP does not support the Teton Order Routing at this time.
We do not know when (or if) they will eventually offer this service. It is really up to them to decide when they will make it available.
