Date/Time: Wed, 05 Mar 2025 01:49:06 +0000
CBOE VIX real-time on Denali?
View Count: 674
[2022-01-11 23:17:17] |
jackbravo - Posts: 71 |
Hi, Does/Will Denali support real-time VIX data? I currently have Denali + Package 11 + Teton routing through Stage5. Thanks. |
[2022-01-12 20:26:38] |
John - SC Support - Posts: 38380 |
Denali does have data for the CFE (CBOE Futures Exchange) and the VIX futures. Refer to the Setup Instructions here: https://www.sierrachart.com/index.php?page=doc/DenaliExchangeDataFeed.php#SetupInstructions_CFE If you are wanting the VIX Index, then that is on the Sierra Chart Exchange Data Feed and we do not have specific timing on when/if that will move to Denali. For this data, refer to the Setup Instructions here: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SetupInstructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
