Date/Time: Wed, 05 Mar 2025 01:19:40 +0000
Downloading Continous Conctract Data BUG
View Count: 419
[2022-01-11 15:14:10] |
Witchislav - Posts: 2 |
i cant connect with my Rithmic trading account. The chart data isnĀ“t downloading. Could you please help me with Remote Assistant?
[2022-01-11 17:44:00] |
John - SC Support - Posts: 38380 |
Follow these instructions to connect to Rithmic: Rithmic Trading Platform Service: Setup Instructions Then, you need to be aware that Rithmic only sends data for the last five days for their data, therefore you will not be able to use the Continuous Futures Contract feature with their data. Refer to the following for more information on historical data from Rithmic: Historical Data on the New Rithmic Connection If you want to get proper historical data, then you will need to use the Denali Exchange Data Feed. Refer to the information here: Denali Exchange Data Feed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
