Date/Time: Wed, 05 Mar 2025 01:49:04 +0000
Teton order Routing
View Count: 615
[2022-01-11 15:13:41] |
User525384 - Posts: 37 |
I am interested in switching from my TT to SC order routing. Please advise as to what I need to do on my end. Thank you. (very happy that you guys did this)
[2022-01-11 15:47:33] |
You really just need to ask your broker to do this for you. Please let us know who your broker is and we will let you know if there is anything else you need to tell them or any guidance we can give you.
[2022-01-11 17:53:28] |
John - SC Support - Posts: 38380 |
Once your broker has changed your account, then you will need to go through these Setup Instructions starting at Step #6: Sierra Chart Teton Futures Order Routing: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
