Date/Time: Wed, 05 Mar 2025 18:29:37 +0000
2 systems
View Count: 536
[2022-01-11 15:11:11]
User267000 - Posts: 6
Thank you for your answer for real data and message log.how can I disconnect one of systems to data feed real time without turn off?
I need that 2 systems work .but one of them use Emini data feed and other work with delay data
[2022-01-11 17:38:10]
John - SC Support - Posts: 38386
If you want one system to get data in real-time and the other to get the Delayed Streaming Data, then on the system for which you want to get the Delayed Streaming Data, set the following:
- Global Settings >> Data/Trade Service Settings >> Current Selected Service: SC Data - All Services
- Global Settings >> Data/Trade Service Settings >> Common Settings >> Allow Support For Sierra Chart Data Feeds: No
You will then only get the delayed streaming data to that system. The other system will then have access to the real-time data.
[2022-01-14 15:42:18]
You also need to reconnect to the data feed after following the instructions in the prior post:
Complete information about this:
Denali Exchange Data Feed: Connections
Date Time Of Last Edit: 2022-01-14 15:43:05
