Date/Time: Wed, 05 Mar 2025 01:34:41 +0000
new Broker
View Count: 527
[2022-01-11 09:41:00]
User491428 - Posts: 87
if i change the broker, how i set this in sierra ??
[2022-01-11 15:09:55]
It depends what broker you want to change to. Let us know.
There are different set up instructions depending upon the broker and the particular backend order routing market data system being used.
[2022-01-11 15:39:36]
dorman its the new one. i will use teton orderrouting
[2022-01-11 17:50:21]
John - SC Support - Posts: 38380
Then follow these instructions:
Sierra Chart Teton Futures Order Routing: Setup Instructions
