Date/Time: Wed, 05 Mar 2025 01:14:48 +0000
sierra to low
View Count: 522
[2022-01-11 08:32:10] |
User491428 - Posts: 87 |
hallo, after the last update sierra chart is to low. Whenever I place an order or change a stop at the cathedral, it takes a while. this behavior did not exist before. what could that be. the PC resources are not being used to full capacity.
[2022-01-11 14:50:53] |
Refer to this help topic regarding any performance issues: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often Also, refer to: Overview of Trading: Sierra Chart Configuration for Most Low Response Time Trading First step would be to just simply open a single chart and/or Trading DOM and see if you notice the issue. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
