Date/Time: Wed, 05 Mar 2025 01:49:39 +0000
Trading Activity Log export contains other price format then SC activity log
View Count: 420
[2022-01-11 07:23:06] |
Stephan_CH - Posts: 18 |
Currency price value is shown in SC correct according my windows setting (region Switzerland) with decimal point. All is fine. If I show my Trade Activity Log, still all is correct, but if choose on menu File > Save Log as OR File > Export then the export file has eliminated the decimal points like the us format. For example future LE price 137.500 (as decimal point) will be exported and shown in export file as 137000.000 (like US format where a decimal point is thousand separator only) I don't find any settings to change for correct output. Thanks for any tips and support. Regards, stblaser |
Private File |
[2022-01-11 07:27:23] |
This is the native price format used by the exchange. This is in the case of when using the Sierra Chart Order Routing Service. Also we see you are using the older TT based Sierra Chart Order Routing Service. Have your broker move you to the new Teton order routing service which is superior: Sierra Chart Teton Futures Order Routing We recommend moving as soon as possible. You will pay no transaction fees. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-01-11 07:30:00
