Date/Time: Wed, 05 Mar 2025 01:44:38 +0000
[User Discussion] - Funding Rates
View Count: 643
[2022-01-11 05:30:26]
User486817 - Posts: 83
hello,
is there an indicator to display the binance crypto futures real-time funding rates on a chart? being able to track this in SC would be very useful. if this is not possible, would you consider adding this as a part of the data feed? this is a link to the data i'm speaking of: https://www.binance.com/en/futures/funding-history/0 or you can google "binance funding rates."
there are two funding rate feeds, the USD-M and the COIN-M funding rates. USD-M is when you are using tether as collateral and COIN-M is when you are using whichever coin (other than tether) as collateral.
kindest regards,
[2022-01-11 15:04:07]
1+1=10 - Posts: 270
I don't think there is one in the default SC studies nor the user-added studies. Binance does provide an API with the funding rate data so a programmer could create a custom study that retrieved the data from Binance and displayed it in SC. A list of programmers is here:
https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php
The API request from Binance they need is here:
https://binance-docs.github.io/apidocs/futures/en/#get-funding-rate-history
Good luck!
