Date/Time: Wed, 05 Mar 2025 01:26:29 +0000
CQG attached orders Target: Limit Stop: Stop, my question are server orders?
View Count: 593
[2022-01-11 01:20:59]
SkyKeeper - Posts: 40
I am using CQG attached orders Target: Limit Stop: Stop, my question are server orders?
What happens if the internet goes out?
If Target is triggered when the connection is disconnected, then Stop will be canceled?
If Stop is triggered when the connection is disconnected, then Target will be canceled?
image01.PNG / V - Attached On 2022-01-11 01:20:34 UTC - Size: 13.28 KB - 139 views
image02.PNG / V - Attached On 2022-01-11 01:20:38 UTC - Size: 13.18 KB - 142 views
[2022-01-11 07:26:34]
How this works in the case of CQG is explained here:
Attached Orders: Management of Attached Orders when Trading Service Supports Server Side OCO Only
For proper server-side OCO and bracket orders, you need to use the Teton Order Routing Service:
Ask your broker to move you to this service. Hopefully they do support it or will soon.
Date Time Of Last Edit: 2022-01-11 07:26:46
[2022-01-11 07:31:04]
my broker Ninjatrader they refused to cooperate and implement Teton, they say it's not their problem
[2022-01-11 07:36:21]
Excellent. Good to hear that. You can always move to a broker that supports Teton and save on transaction fees and have better quality service.
Date Time Of Last Edit: 2022-01-11 07:36:28
[2022-01-11 07:46:39]
Can you create a post listing these brokers? And replenish it?
[2022-01-11 07:48:17]
does ampfutures support Teton?
[2022-01-11 14:46:36]
The list of brokers is here at Step 2:
Sierra Chart Teton Futures Order Routing: Setup Instructions
No AMP does not yet support the Teton Order Routing Service.
Date Time Of Last Edit: 2022-01-11 14:47:51
