Date/Time: Wed, 05 Mar 2025 01:17:09 +0000
changing data needs
View Count: 434
[2022-01-10 20:49:56] |
Jgeidson87 - Posts: 12 |
i have been trading futures but im going back to trading listed stocks. I just downgraded back to my old package instead of denali but i cant figure out if i have everything setup correctly. What do i need to activate to get access to large and small cap stock live feed do i have it setup correctly and is it the proper packages for my moneys worth
[2022-01-10 22:24:00] |
John - SC Support - Posts: 38380 |
The main item is to have the Sierra Chart Exchange Data Feed with the U.S. Equities exchange active. You have taken care of this, so you are good there and you should be getting real-time data for the U.S. Equities at this time. With regards to your package, it is up to you whether you want to be on Package 3 or 5 (if you are not trading Futures at all, then you do not need to be on package 10, 11, or 12). Refer to the differences between packages 3 and 5 here: Description of Service Packages and Pricing: Packages For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
