Date/Time: Wed, 05 Mar 2025 01:49:18 +0000
ZigZag Text Labels not appearing in SC 2342
View Count: 569
[2022-01-10 17:29:05] |
User796776 - Posts: 95 |
Updated to 2342. Several charts using ZigZag study no longer display text labels. Repo: 1. Created new ES intraday chart 2. Enabled label settings as in image. 3. No labels are displayed Rolled back to 2339 and labels display correctly. Date Time Of Last Edit: 2022-01-10 17:35:32
[2022-01-11 16:50:46] |
Ez - Posts: 53 |
I just noticed the same issue. Downloaded the Pre-Release version (2343). It's working ok there. Date Time Of Last Edit: 2022-01-11 16:58:44
[2022-01-11 16:56:49] |
Update to prerelease version 2343. This has been resolved: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
