Date/Time: Wed, 05 Mar 2025 01:22:27 +0000
poc isue
View Count: 481
[2022-01-10 13:37:02] |
User278398 - Posts: 291 |
hello, after i used vp study and check in draw mode "poc,vah..." i got the poc line. how can i get the bid X ask text of it (near the line) regards |
[2022-01-10 18:08:15] |
John - SC Support - Posts: 38380 |
You can get the BidxAsk text displayed for each bar in the Volume by Price study by using this Input: Volume By Price Study: Display Volume in Bars If you are looking for the Total Volume Above/Below POC or the Ask - Bid Above/Below POC, then refer to the following: Volume By Price Study: Viewing Volume Profile Text Information For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
