Date/Time: Tue, 26 Nov 2024 04:50:45 +0000
[User Discussion] - Alarms on VbP
View Count: 993
[2014-04-08 12:44:35] |
User23815 - Posts: 210 |
Using the Volume by Price study. I have Highlight Value Area and Extend Value Area set to yes. Is there a way to set an alert at the extended high and low lines of the Value Area? Thanks
[2014-04-08 18:46:07] |
No. You would have to use the Volume Value Area Lines study for this.
