Date/Time: Wed, 05 Mar 2025 02:12:56 +0000
[User Discussion] - Multi-Timeframe Volume Profiling
View Count: 900
[2022-01-10 02:26:18]
Predicate - Posts: 8
I'm inquiring if it's possible for me to implement one of my ATAS charts in Sierra Chart and, if so, how identical I can make it. It has 15 minute bars with histogram style profiles. Numerical values are disabled and the point of control has an outline. There's a volume filter that will color the price bar if over a certain number of contracts. There is a 1 hour profile behind the bars, with an outline to show the width/spread of price and a volume total. The 1 hour profile also has the point of control identified.
Attached is an example of the chart.
image6a1c25a960e903283b4c2b0c4db1129a.png / V - Attached On 2022-01-10 02:25:46 UTC - Size: 111.17 KB - 208 views
[2022-01-10 04:58:37]
Tony - Posts: 550
2 VbP studies
VbP Study 1:
Ticks Per Volume Bar (In:32): 1
Volume Graph Period Type (In:33): Multiple Profiles Based On Fixed Time
Time Period Type for 'Fixed Time' (In:34): Minutes
Time Period Length for 'Fixed Time' (In:35): 15
VbP Study 2:
Time Period Length for 'Fixed Time' (In:35): 60
Use Transparent Draw Style (In:52): Yes
Transparency Level (In:53): 70
Just the basic part, I don't have time to find out other feature you mentioned,
hope someone else will answer the rest part of your question.
Sierra's VbP Study (Volume by Price, aka Volume Profile) seems a bit overwhelming for
new users, but if you are willing to test each input and read the document, it will pay
off very well in the long run, imo.
Date Time Of Last Edit: 2022-01-10 05:09:08
[2022-01-13 01:39:01]
You didn't answer either part of my question. I was not asking how to do something. I was asking if something could be implemented, and if so, whether I would be able to reproduce it identical to the original. If the answer to either of those was a no, then I could save myself a lot of time wasted toying with various option combinations with no result. How the information is visually parsed is more important than the information itself.
[2022-01-13 02:38:10]
SKZ90 - Posts: 74
That's not how you get help.
lol
[2022-01-13 10:00:03]
User431178 - Posts: 604
You can get pretty close to your image.
imagemulti-vbp.png / V - Attached On 2022-01-13 09:59:52 UTC - Size: 31.14 KB - 211 views
[2022-01-13 20:28:43]
Pretty close is an understatement, User431178. That's about as identical as one could expect across platforms. Thanks for that screenshot.
Musing: Nothing quite like asking a person about planting seeds and then having them tell you how to dig an irrigation ditch.
