Date/Time: Sun, 04 Oct 2026 09:10:07 +0000
Quote Board Volume
View Count: 822
| [2022-01-09 23:47:31] |
| User445772 - Posts: 3 |
Good day, I received a .cht (chart) file and saved it into the data folder All the charts open without any issues. The only thing that is not populating are the volume totals. I have tried numerous methods but still having issues. Using delayed data. Please help. Thanks, |
| [2022-01-10 07:00:38] |
| Tony - Posts: 725 |
I believe the volume showed in Quote Board received data from a broker, without live data, you won't get any real volume # You can only get daily volume by calculating the accumulative volume of all bars printed in current day. Here was the discussion: Display total volume for the day as text on the chart Date Time Of Last Edit: 2022-01-10 07:01:26
| [2022-01-10 15:27:05] |
Make sure the symbols in the Quote Boards are correct. Translate them with this Edit menu command: Edit Menu: Edit >> Translate Symbols To Current Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
