Date/Time: Wed, 05 Mar 2025 01:17:36 +0000
CFE Symbols
View Count: 555
[2022-01-09 22:06:51] |
theunknowntrader - Posts: 112 |
What is the difference between VX?##_FUT_CFE | S&P 500 VIX - CFE VX?##-CFE | S&P 500 VIX - CFE |
[2022-01-09 23:05:30] |
This is the new symbol format: VX?##_FUT_CFE | S&P 500 VIX - CFE Just use one or the other but you should use the new symbol format. Do not use both. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-01-09 23:05:42
[2022-01-09 23:45:21] |
