Date/Time: Wed, 05 Mar 2025 01:22:43 +0000
bitmex
View Count: 607
[2022-01-09 19:26:42] |
User313942 - Posts: 17 |
HI . how i set live trading ? i connected to bitmex by API . i see charts but the account is (sim) and the connection is not stable. how i set full live triding ? how set shoulders ?
[2022-01-09 20:13:41] |
We no longer provide any technical support for BitMex trading. We cannot help with this. Sierra Chart should not be used for crypto currency trading. Only charting.
[2022-01-09 20:31:50] |
But in simulate mode it is work . the live mode is not working ?
[2022-01-09 20:34:57] |
We cannot help with it. Our advice is do not use BitMex. If you would like a refund we will do the refund. Please do not use BitMex. We cannot help with BitMex issues. Take our advice. Do not use it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
