Date/Time: Wed, 05 Mar 2025 01:17:48 +0000
Is there any way to see what prices on the other chart
View Count: 503
[2022-01-09 18:05:51] |
hoanheo2021 - Posts: 2 |
For example I have 2 charts open, When I move the cursor at a specific bar on chart #1 I want to know what prices are on chart #2. The Tool Value and Compact Tool Value are useless because they only show what on the active chart, Header line is also useless because it only shows what prices are for the last bar. |
[2022-01-09 20:43:11] |
Refer to: Chart Drawing Tools: Global Cursor (Tools >> Global Cursor On) (Global Cursor) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-01-09 21:05:30] |
Hi SCE, thank you for your reply, but it still doesn't resolve my problem, because I have tried the global cursor, the problem with global cursor is when activated it only shows both "last price" and "date" for symbols that trade in price ranges that are not so faraway from each other. For example if I use the global cursor on Stock (AAPL) and a small company (PBYI) I won't be able to see the "prices" because AAPL trades around $170-$200 price range and PBYI price range is only $3-$10. So the horizontal line of the global cursor won't be visible on the PBYI if the cursor is on AAPL chart and vice versa, only vertical line works Thank |
[2022-01-09 21:08:08] |
We really are not sure what you are looking for or how something like this would work when there are different prices between the charts. So there is no functionality for what you are looking for.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-01-09 21:08:21
