Date/Time: Wed, 05 Mar 2025 01:14:38 +0000
DOM VBP Study Text
View Count: 740
[2022-01-09 17:20:01]
User92573 - Posts: 547
Dear Support
I can't seem to adjust the text size on the Volume By Price I've added to the DOM.
In addition I've added a "General Purpose" column that I can't type in?
Any help appreciated.
Many thanks.
imageText Size.png / V - Attached On 2022-01-09 17:18:26 UTC - Size: 39.51 KB - 163 views
[2022-01-10 16:37:30]
John - SC Support - Posts: 38380
Refer to the following:
Volume By Price Study: Volume Numbers Text Color and Size (SG7)
The General Purpose columns are meant to be utilized by ACSIL studies. You can not interact with them otherwise. Refer to the following:
Global Trade Settings Windows: General Purpose 1 / General Purpose 2
[2022-01-10 17:12:08]
Hi John
I still can't change the font size in the Volume Histogram.
I've set:
Ticks Per Volume Bar (ln:32) = 1
Display Volume in Bars (ln:46) = Total Volume
Volume Bar Calculation method (ln:48) = Total Volume
Bid Volume and Ask Volume colouring method (ln:49) = None
*** Text font size (ln:110) = def = 10. "No matter what I change this to it does not update the font size?"
Have I misread something?
Many thanks
[2022-01-10 19:18:05]
You do not change the Font Text Size on the Inputs, that is for the text Above/Below the profile. As mentioned above, you need to change the font size by modifying Subgraph 7. Refer to the following:
