Date/Time: Wed, 05 Mar 2025 01:15:21 +0000
possible to move candlesticks over to the left so not overlaying right side VBP? pic...
View Count: 552
[2022-01-08 19:52:33]
HeyUgly - Posts: 251
curious if possible
wanted to shift the candlesticks/daily vbp over to the left so it doesnt overlap the weekly VP on the right hand side, this possible? or i just have to thin the volume bars on the weekly? id prefer not to if possible
Date Time Of Last Edit: 2022-01-08 19:53:02
imageCapture7.PNG / V - Attached On 2022-01-08 19:52:25 UTC - Size: 34.54 KB - 170 views
[2022-01-10 05:18:38]
Tony - Posts: 550
Not sure if your weekly profile is drawn on the last bar of the chart, if not,
you could try this:
Under "Chart" menu, uncheck "Lock Fill Space", and press right arrow key
(I think, or maybe left) to increase fill space and lock fill space again.
Date Time Of Last Edit: 2022-01-10 05:21:50
[2022-01-10 08:48:34]
User907968 - Posts: 833
Follow the instructions here - Volume By Price Study: Right Aligning Volume Profiles with Space on Right Side of Chart
