Date/Time: Wed, 11 Nov 2026 23:24:54 +0000
display vertical volume by chart
View Count: 1038
| [2022-01-08 18:06:50] |
| User278398 - Posts: 296 |
hello, i saw in some video that some one which press on TRADE -> "show data market colums" and then he got the volume inside the chart like in the attach pic file. when i do that i dont get the volume as he got. what i need to do to get the same display? regards. |
| [2022-01-10 15:39:39] |
| John - SC Support - Posts: 48504 |
In that particular image, what you have circled is a Volume by Price study that is right-aligned. Refer to the following: Volume By Price Study: Right Aligning Volume Profiles with Space on Right Side of Chart And also refer to the section right after the above, which gives instructions to put on a single right-aligned profile. -- There is also the ability to display a profile for the data in the DOM Columns. Refer to the following for this: Global Trade Settings Windows: Show Volume Bars (Trade >> Customize Chart/Trade DOM Columns) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
