Date/Time: Mon, 25 Nov 2024 23:45:08 +0000
How can I search for all The programming help post on the forum ?
View Count: 970
[2022-01-08 17:40:42] |
GravisHTG - Posts: 306 |
I try to write Programming help in the right case , it did not work thanks in advance ! |
[2022-01-08 19:21:22] |
58LesPaul - Posts: 429 |
See if there is a thread here to help! https://futures.io/sierra-chart/ |
[2022-01-09 14:16:37] |
SpearChucker - Posts: 104 |
If you just want to filter the forum posts to see just Programming Help posts. Then scroll to the bottom of the forum page and on the bottom right you will see a drop down list and an Update button. The drop down list has None, User Discussion, and Programming Help. Select the one you want and hit Update.
[2024-01-23 15:56:56] |
User14953 - Posts: 236 |
What's a good way to filter the forum posts to see just the User Discussion or Programming Help posts? From the above post, "The drop down list has None, User Discussion, and Programming Help. Select the one you want and hit Update. " This feature isn't visible here. Date Time Of Last Edit: 2024-01-23 15:57:31
[2024-01-23 17:13:49] |
John - SC Support - Posts: 36286 |
The option that was referenced in post #3 has been removed. As such, there is not a way to search for threads that have been set a certain way. You can always search the forum in general for terms at the top of the page. Or you can use Google with the +site:sierrachart.com/SupportBoard.php option to just get results from the Support Board.
